mf94_4x4
- December 1, 2003
- Massachussetts
- 2007 Mountaineer
Hi all, ive been wanting to get a KKM style intake for a while, but being a poor college student 100 dollars seemed to be a bit too much especially since i figured i could fabricate an MAF adapter myself.. so i finally got around too it.
I went over to autozone and picked up a washable cotton fiber K&N knockoff for $24, and a 3" exauhst adapter for 1.49, then down at the Shop where i work i made a cardboard templated to mount up to the MAF and then using the template, cut a peice out of some scrap metal plate, marked and drilled holes to bolt it up to the MAF, then using a 3" hole saw, i cut out a hole in the plate. Then welded up the 3" exahuast adapter to the peice i cut and drilled and then ground the edges smooth and sprayed the outside with some black krylon, looks damn good if u ask me.
Then i bolted it up to the MAF, clamped on the filter, plugged the vacum lines for the stock Air Box and that was that. Took a good 2 hours to get it all done. I noticed some increased throttle response and a pretty throaty sound when i get on it, we will see if it does anything for gas mileage but im imppresed so far.
Anyone else try this before??
Seems like a good $$ saver if youve got the tools and skills. It was easier than i thought it would be too.
Ill see if i can get some pictures up soon.
