Hood Support Strength? | Ford Explorer Forums
SHOBrad
New Milford, CT
1997 Mountaineer V8 AWD
Does anyone know what the strength (in lbs, N, etc...) of the hood supports are? Mine are shot and a friend is getting rid of some sets that look identical (length, OD, attachment type). i can have them but I want to make sure they will work!
explorer hoods are not real heavy.
Either way the hood shocks are super cheap OEM and even cheaper after market.
well, I tested a few and believe it or not, it took the strongest one you could get in that package to work correctly. The gas springs I ended up using were 130 pounds of force each!
SHOBrad, do you have the manufacturer and part number to share? I need to get a set put on ours but want something that will work without having to worry about the hood coming down on me.
I have a hood support rod now, I haven't bothered to replace the struts yet. I realized it was a problem when I was working in the engine, then after I took my head out, and was by the grill, BAM! I guess my old ones don't hold up in cold weather....
I'm just a little gun shy now. So I just use my support rod. I really need to replace the shocks though.
