- March 3, 2002
- Elkridge, MD
- 04 4Runner, 22 Silverado
Get a large pry bar & pry on it.
Actually can you hear the cable disengage the latch when you pull on the release? Try spraying some wd-40 or PB blaster on the latch. And please don't try pulling on the release hard, it can snap the cable off.. If all else fails, get a 1/4" drive ratchet & 8mm socket along with some swivels & some extension and remove the latch.. Just remember the cable is still attached so hopefully you don't snap it off..
