How do you determine Gear ratio 1998 explorer | Ford Explorer Forums
bertomax
Albuquerque
1998 ford explorer sport
I noticed on carparts.com that they asked for the gear ratio. I found two tags on the rear diff. s6156r and al10887j15.
Anyone have any insight?
it should also say on the top line something like "8.8 373" the last three numbers (373, 355, 410) will be your gearing, as long as someone hasnt changed them to something else.
I bet the Ford dealer knows an he'll tell you for nothing. using those numbers and your VIN,. He also might be able to tell you if the original parts in there.
Do you realize you're responding to yourself?
On your drivers door there is a sticker, on that sticker it says AXLE CODE
get the number and google it = gear ratio
410Fortune is right, did that for mine, found out mine's a 3.73 limited slip
