Took your advice and hooked new lines up so each thing gets its own vacuum source. I may of had something not hooked up before I worked on it. I'm thinking I never had a vacuum line going to my fuel valve before I took it apart.Any ways here is a new picture of what I have it now. The a/c capsule thing only has 1 vacuum nipple no elec plug or any other nipple coming out. So what does it do?? some kind of vacuum reservoir?
<snipped pic>
This is what I call the Capsule. It only has one nipple for vacuum what does it do??
So, close, but you have the idea..
The capsule thing (as you call it) is a vacuum reservoir. It doesn't "do" anything other than hold vacuum.
This is where you need to make a change. The vacuum reservoir is used to help keep vacuum available for use by the blend door. That is the door in the dash that moves with the a/c controls.
So, What you need to do is take the vacuum line that runs to inside the vehicle (it appears to be the top on in the pic I snipped out, running into a wire harness) and connect it to the capped T you have @ the canister (capsule).
Once you do that cap off the open port you just made at the vacuum tree.
That should be the last thing you have to modify to get everything working..
BTW, if you really didn't have vacuum running to your FPR you have been running with higher fuel pressure. That means you gas mileage "may" go up a little now that you have vacuum going to the FPR.
Oh yea.. Just so you know, since you have a 1991 you have what looks like a MAP (manifold absolute pressure) sensor. It is actually a BAP sensor.. You can see it in the pic I snipped. It is on the firewall, has an electrical connector and what looks like a vacuum port on it with some white plastic around it. That white plastic is supposed to make it so you don't hook anything to it. It is using it to know the barometric pressure to help figure out the mixture. I'm just letting you know since I've seen some with that plastic broken off and then someone hooked a vacuum hose to it thinking it was supposed to have it.
~Mark
