You mentioned in another thread that you have the OHV engine. That engine does not have anywhere near the problems with timing chain failure as does the notorious SOHC engine. No hydraulic tensioners, plastic guides, etc.
Okay good to hear. I remember this is why I bought this when I did because it has a more reliable engine than the SOHC and it only had 163k km on it at the time. Yes I have the OHV engine. Sounds like the timing chain assembly on the OHV is simplier if it has no guides or tensioner.
yep yep!!! original motor and trans!!!! (im not sure but i have a feeling it had to do with using full syn 5-30 every 3-4k... but yeah! the rig is at 350k around now! it only leaks from the rear main and output shaft a bit, but hey what should i expect ive been lucky so far with my SOHC and 5r! hope you have the same luck ihave!
On my '97 SOHC I replaced the left cassette only, at 258,000 miles. It was destroyed, and the timing chain jumped one tooth when it happened, punching a nickel sized hole in the valve cover.
