how much brake fluid? | Ford Explorer Forums
thejoker954
96 EB
ok so I'm doing the rear brake lines on my 96 EB.(had to stop short and the line blew) I was just wondering to refill the lines about how much brake fluid should I get?
Thanks in advance:)
:rant:and please if all you're gonna tell me is to do a search, I suggest you do a search on where you can shove it. :rant:
Thanks in advance:)
Get at least a quart, it's a good time to flush the entire brake system. Brakes and cooling systems need periodic flush, those two and diff fluid are the most overlooked maintenance items.
Agreed, I'd get around a quart, but instead of the 32oz jugs I like to get the 12oz, so if I don't need the 3rd one, I don't open it so it doesn't go stale from absorbing moisture.
