mystic04
- May 21, 2008
- delaware
- 1994 eb explorer
I've been chasing a intermitant miss so I started by changing my plugs which were white from a lean condition so I changed the fuel filter and ran some seafoam through the tank then checked fuel pressure I get 30 psi with key on engine off then 20 psi at idle and somthing like 30 when I hit the gas and if I hold say 2500 it will settle back down to about 22 psi so does any one know what the fuel pressure should be from the factory and has anyone had this problem before thanks
