Rupert8
- August 25, 2013
- Northern California
- 1992 Ford Explorer
Hello,
My 1992 Eddie Bauer Explorer has just begun to stumble when I am trying to start it, but only when it has sat for a few hours.
I tested the fuel pressure: with the ignition on (and the fuel pump running) the fuel pressure is 10PSI. When I get it running (after one or perhaps two attempts) it fires up fine and the pressure is then 30-35PSI.
When I remove the vacuum line from the pressure regulator, the PSI climbs to 45ish.
The system holds pressure at around 35PSI after I shut off the engine.
Does the initial low pressure after the car has sat for a while indicate that the fuel pump needs to be replaced?
I have serviced the car (spark plugs, filters etc. including fuel filter) recently.
Yet another thing going on this Explorer.... at least this forum is a great resource.
Many thanks for all the input.
