nice job me like it alot too how did you connect the new body to the car screw it direct to the dashboard or what?? or the floor ?? anyway its fabulus done
Look at the second picture in the second post. Above the rear crosspiece in the console, you will see 2 threaded holes in the frame of the dash. (Factory mounting points.) I bolted L-brackets to the crosspiece and screwed the L-brackets into the factory holes.
There are no mounts to the floor. The bottom edge of the vertical pieces is cut at an angle, allowing the console to "fit" on the floor.
