arco777
- April 6, 2008
- 1994 Explorer 2dr 4x4
How to change your Transfer Case Fluid - 91-94 Explorer 4WD
You will need the following at a minimum:
-2qts Mercon Automatic Transmission Fluid or equivalent
-3/8" ratchet (may need a breaker bar)
-13mm socket
-Oil drain pan
-Paper towels/rags
-Fluid pump (see picture)
You may want to jack up the vehicle slightly to have more room underneath to work. Always use jack stands and be safe.
Pictured:
One gallon bottle Dex/Merc ($18), one fluid transfer pump with lifetime warranty ($10). This fluid pump is really handy and works great for pumping gear oil into differentials too.
-13mm socket
-Oil drain pan
-Paper towels/rags
Pictured:
