How to check front tie rod ends? | Ford Explorer Forums
96ExplorerSport
Pittsburgh PA
96 X Sport 4.0L OHV, 4WD
Hi,
Is there a way to check front tie rod ends to see if they are bad? What are the symptoms of them going bad? Mine are off the X right now and I'd like to know if I should replace them.
Thanks
I've owned a car for a year and I am not sure how old tie rod ends are. They do not feel look loose and there are no alignment problems. If I try to turn them by hand I can feel resistance.
Wiggle the steering wheel side to side, then get somebody to go under the truck and look at the tierods for play...sometimes you can hear the knocking inside the truck, but most of the times its just the steering box.
If you can see to well, grasp the tierod and if you can feel movement then you got a bad tierod
Thanks guys!
