how to put tranny dip stick tube back | Ford Explorer Forums
kw4359
98 explorer limited
I pulled my dip stick out to check tranny fluid,and tube came out of tranmission. How do i put it back in?
There should be an "eye" towards the top of the tube that has a transmission to engine bolt through it. If that "eye" has broken off, you should replace the tube to keep it from coming out again. If the bolt is missing, then you should replace that. As far as getting the tube back in, you'll have to get underneath and "fenagle" it around until you can get it to pop back in. It can be a pain, good luck! And welcome to the forum!
Welcome to the site! You should be able to just push it back in place. There should be an o ring on the bottom to seal it. There also should be a bracket on the dipstick tube that bolts the tube to the engine block. Either the bolt broke/fell out, or the tab that the bolt goes through broke or rusted off.
Beat me to it!
