- March 4, 2007
- anaheim hills,california
- 95 ranger 4x4/ 91 X 4x4
...All the information supplied and the work done was done on, and for, my 95 4 cylinder, 8 plug, Ford Ranger..There may be differences in your model or year but this is what I needed and how I do it..
..You do not need to remove the upper intake and with a little creativity, it's really not that hard of a job..
_____________________________________________________
...These 4 cylinder motors are particular to what plugs they run and generally call for Double Platinum plugs while later models do call for Iridium plugs..Motorcraft Spark plugs are first choice but due to cost difference, Autolite plugs are commonly substituted..
Getting the info you need
..Most of us have bought used vehicles or have had others do the maintenance work on our vehicles so pulling the old plugs out and running to the parts store to get them matched may be a poor choice for your vehicle..
..Before you run out to get plugs and wires, find out what plugs you do need for your vehicle..Most all of this information can be found under the hood within stickers that are placed on your radiator core support..
..This information is particular to your individual vehicle and will save you from getting general information from your parts dealers..
Vehicle information and Vacuum diagram..
Enlarged view of the vehicle information..
Enlarged view of the plug information. This is where you find what type of plug and it's gap..
..and as a Bonus I'm including the 2.3L serpentine belt with A/C diagram..
..You will notice the following information of the enlarged view of the plug information that it calls for:
Spark Plug - AWSF-32PP
Gap - .042-.046
When using the Autolite Competitor Cross reference for these, this is what comes up..It shows the original part number to be a Motorcraft plug and their options to that plug..
http://www.autolitecatalog.com/Competitor.aspx?b=A&pn=AWSF-32PP&em=True
For more information on a particular plug you can click on their part number and get actual part details to that particular plug..(Although not shown, it also shows all vehicles this plug cross references with)
...With this info in hand I made it out to the parts store and got the parts I needed for this swap..
(Note: a single "P" on plugs denotes Platinum while a double "PP" represents double platinum)
..I get lifetime warranty on these Bosch wires PN 09765 and after five years they are due for a chainge..
The Plugs I got are the Autolite APP104's..
..While I'm picking up plugs you will notice in the above picture 1 package of anti seize for the spark plug installation and also 1 package of a spark plug boot protector..
..Although almost all wires now come already prepped with boot protector on each end, I have in the past ran in to boots missing this product on one end of a wire and it helps to be prepared..BTW, these packets only cost .99 cents a pack and are worth a small fortune in repairs if you don't use them..
..A common issue of not using anti seize on plugs are breaking plugs when later trying to do a plug swap..
..The boot protector locks out moisture and prevents wild arcing as shown in this video..(you can also get these arcs on the other end of the wire if the boots don't have this sealant on them)
Gap - .042-.046
