How to remove front driveshaft 2000 Ranger?? | Ford Explorer Forums
two rivers
2000 Ford ranger
working on a 2000 ford ranger 4x4. How to remove front driveshaft.
Welcome to the forum.
I retitled your thread to "How to remove driveshaft 2000 Ranger?? And I'm moving the thread to our Ranger forum.
same procedure as you would with the rear.
i like to mark the flanges with a marker so i can put the driveshaft in exactly the same orientation.
jack the truck up, loosen the bolts you can access and then put the car in neutral to rotate the shaft to get the other bolts off.
