How to remove the fan clutch on my 96 explorer | Ford Explorer Forums
plafullspirit
Bedias Texas
1996 ford explorer V8 5.0
My water pump went out on my explorer and I removed it. My issue is now I cannot get the fan, fan clutch and pulley off. Unfortunately I asked someone for advice and they said it was right hand threaded. So while trying to remove fan by turning it to the left I ended up with the water pump housing coming completely off with only the shaft remaining and still attached to fan,clutch and pulley. I am assuming that it is probably left hand threaded but unsure of how best to try to get it off now. I have used a variety of tools to try and hold the shaft while turning nut to the right but have been unsuccessful at this. Any ideas on how to best attack this issue ? At my wits end now.
Thanks,
Larry
New fan clutch, and pulley.
Cheap easy.
The fan shroud is stamped. tells you which way left or right thread.
