roush9799
- October 6, 2012
- 2016 Ford Explorer XLT
I got mine done yesterday. I also did the tie rod ends since the boots were shot on them too, plus I'm getting it aligned. Now I have a completely greasable front end.
TIP: One problem I had was when removing the hub assembly, I couldn't get it low enough to clear the bottom ball joint, as I was replacing uppers and lowers. To gain a lot more room in there, I found that removing the caliper, and also removing the axle nut, I was able to set the caliper on a 5 gallon bucket behind the axle. I was able to slide the shaft in, and set it up sort of on the sway bar way out of my way when working on the bottom. As for the axle assembly, I set it forward of the axle our of my way. That gave me plenty of room to get in there and tackle these things. I went ahead and removed the upper a-arm. I tried to get the tool at it, but it was no use. Plus I had a 50 ton shop press to push them in and out with. Bottoms, I used the tool no problem.
TIP: I had trouble getting the bottoms to separate. The separator didn't have enough pitch to do the job, so I took 2 large flat washers and cut a section out of them and placed in there, then drove the tool in with that and they popped right apart.
