goatman
- January 22, 2004
- Oakdale Tn.
- '05 XLT V8
They are about as wide as the little cutout in the plastic bar. I have mine mounted under the nudge bar mounts - actually, my nudge bar mounts use the same bolts as the tow hooks; I just needed a 6mm (1/4") spacer plate between the bottom of the nudge bar bracket and the tow hook.
Hey JCUZ, did your bar come to you so it could be mounted under your tow hooks. Me and N2FORD are bound to something similar to you. Nearest we can seem to come is to have something custom made or cut a bar that is close and weld the mounting plate on.
