With the help of my buddy who's done them before, I changed my brakes last night in my '02 Eddi Bauer for the first time. I just got tired of the ridiculous shop prices for what I've heard was a relatively beginner's job.
It wasn't all that difficult, but I had some problems putting the new clips in as well as placing the new pads on the inside side of the rotor (if that makes sense). Again, luckily I had my buddy there to "supervise" my first real project and offer some assistance.
Based on research, I went with the ultra premium NAPA rotors and the Bendix semi-metallic pads. I really couldn't wait to order online, so a set of front rotors and pads cost me $260.
Now my questions...
1. I wish I took a pic for you guys but the inside pad on the passenger side had some really odd wear. The top side of the pad was worn, but nothing extravagant. The bottom of that same pad was very very worn. Each of the other 3 front pads had consistent wear from the top of the pad to the bottom, but this one looked as if one of the pistons wasn't driving one end hard enough?
Is there any way to troubleshoot this? Could a warped rotor cause this? The pistons went back jst fine when putting the c-clamp on each one, and there didn't seem to be any problem after pumping the brakes to reset the pistons after turning the truck back on. Maybe the only thing I can do is wait to see if it happens again in a few months?
2. Regarding the o-ring that goes onto the outside of the rotor, there was a layer of black electrical tape around it. Both of them had this, but the driver's side was coming off so I just removed it and left it bare when putting back on. Is there a reason I'd have electrical tape on that o-ring?
All in all it wasn't a bad job and I'm confident I'd be able to do it myself next time. It's definitely a good job for beginners to try out, and it really feels good that an hour or two of work will save you a few hundred bucks. And I gotta admit I had fun learning and seeing all the parts you always hear about. Now my braking system makes sense since I took it apart and put it back together again.
Thanks for listening fellas!
Now my questions...
