joshhemming
- August 15, 2011
- El Paso
- 93 Aerostar 2wd 3.0L
I picked up a nail 6 months ago in one of my almost-new tires. The nail was in the bottom of one of the tread's grooves.
I bought a Slime tire plugger kit at AutoZone, followed the instructions, used the rubber cement on the plug before inserting it, and the tire held pressure fine until this month. Now it's losing about 5 pounds a day, and the soapy water test definitely shows a little air escaping from the plug.
I obviously need to re-plug it. But how do I get the old plug out? Compared to the rest of the tire, which has fibers woven into it for added strength, the plug feels soft and gooey. I was thinking about using a drill with 1/8" bit to go through the old plug, then push a new plug with fresh rubber cement into the hole. Would this work, or is there a better method?
