I have a P0745 code. | Ford Explorer Forums
gflores353
2002 XLT
Need help. I have a 5r55w with a diagnostic code P0745. I have followed almost every thread I could and I have replaced the solenoid block but I still have the same symptoms. One thread I have not followed was about the possible need to reprogram the PCM. Can someone tell me how to do that?
Thanks
Welcome to this forum! I've moved your post into its own thread in the EEC-V section. Did you clear the code after the solenoid block was replaced? Did you check the internal wiring harness, and the bulkhead connector for a bad connection, broken wires or bent pins?
