I have the pump and i know the replacement procdeure but.... | Ford Explorer Forums
eddie95
2003 Explorer 4.8 AWD
Ok so i bought a replacement ps pump for my 95 explorer ohv. In the box with the pump (it was the one with reservoir all attached) was the pulley installation tool and a bunch of O rings.
In the instructions it says nothing about what to do with them. It does have one packet of them though that it is seals for some other module if equipped. I am assuming mine isn't? That just leaves one Rubber oring and what appears to be a plastic washer. What are these for and how do i put them in?
Thanks
You only use two seals for high pressure line and fluid reservoir. You will remove the high-pressure line with a wrench to get the pump off the truch, then unbolt the reservior after it's out of the engine bay. The position of the original seals will be pretty obvious at that point.
