I just got my 1999 Explorer Sport yesterday... | Ford Explorer Forums
Columbus
Redwood City, CA
1999 Sport 2Door 4WD
Its my first car. Its a gas-guzzler, but I still like it. 1999 Ford Explorer Sport 2 Door, 80k miles, $6500. Yesterday I picked it up from the dealer and found out I had no code for the keyless entry system, but thanks to these message boards, I was able to find the hidden computer module. Thanks a bunch, guys!
I only have one key for the car, so right now my main concern is to get a spare key just in case I lose it. The manual tells the procedure for creating a third key with the Securilock system, but it says I need 2 keys first. Now, my questions are:
1) How can I tell if I have the Securilock system installed?
2) Can I just go to any keymaker and have the key duplicated, or do I need to buy a special (and probably expensive) key from Ford?
3) How exactly does this Securilock system work? Does it encode a magnetic code on the key, or is there some kind of circuitry inside the key itself?
Thanks for your help, guys, and great site!
EDIT: I found this link, but it does not state whether it is possible or not to work around this PATS system or whatever its called. MOHAWK was trying a workaround, but does not state if it worked. Will keep on searching through the forums.
http://www.explorerforum.com/forums/showthread.php?postid=552568#post552568
the key will be thick and you can see where the chip is inserted near where the metal part comes out of the plastic (i've never seen a '98 or newer explorer without it)
expensive blank from ford, or on eBay
there's a passive chip in the key that talks to the PCM
What color is your '99 Sport? any mod plans? if you wanna see a clean '99 sport check out explorerchic's... or if you wanna see some lifted examples, check out my pics or bigger, JasonB's...
Thanks Hokie, but will a keymaker know how to encode a blank ebay key? Can my X encode a blank key using only one original?
My X is Green, and right now I just graduated from college and I have yet to find a full-time job, so no mod plans. I guess when I have money to spare (after I pay for grad school) I'll look into a new stereo system, since most people start from there. I don't think I will be lifting or lowering it, but any other suggestions?
There's a procedure where you program the keys yourself using the ignition. Can't remember it, but i believe its in the owners manual and i'm sure its been written up on this forum
Yeah, I know about that procedure, but the thing is it requires 2 preexisting keys to do it (says so in the manual). I've been reading up in the forum and I have not found anything to confirm that I can do it with just one original key. I'm going to buy a couple of blank keys soon and try it out for myself, but first I wanted to know if anyone has successfully done it.
