i need a body lift | Ford Explorer Forums
i need a body lift
mrjones98e
i want a body lift ,what kind should i get. also will a33x14.50 fit with torsions andbody lift or will i just have to stick with 12.50's
with a 3" bl and tt you may/barely be able to fit 33x12.5......14.5 is uncomprehendable....
Order the PA body lift #PER883 on here Dead Link Removed
you will have to replace two bolts with 1/2" coarse thread bolts or drill out the bushing or whatever, and put a nut on it
This is if you are going to get the lift for your '98 not your '92
If you order PA kit # 883, you will also need the steering extension from kit # 853 (unless you don't care about having your steering wheel connected to your front wheels).
Nope not true, He has a '98 X, which has the same steering at the '98 ranger, only the 95-97 X needs the #853 extention...............All you need is the #883 body lift
If someone was to get the kit for 137.95, how much more would the steering extension from kit # 853 cost?
mrjones98e, this isn't for you, don't get confused, all you order is the #883 kit!
i'm trying to call mary (performance accesories) 520-636-0979, right now and get a price, but i keep getting her answering machine
Below is only for '95-'97 Explorers
1. Here it is $55.00 after shipping for the steering extention (95-97) and then order the #883 kit.
or....
2. $38.60($27.26 + shipping) for the bumper brackets(#883-1 #883-4) and then order the #853 kit.
whichever one you chose. I went option #2 cheaper.... i ordered the brackets from performance accesories and the lift from 4 wheel parts!
