i mailed crutchfield about a wire harness and dash kit this is what he wrote back.......................
The original Ford factory system for your vehicle has an external power
amplifier behind the trimpanel below the right rear window. We have a wiring
harness that will bypass that amp and connect your speakers directly to your
new receiver. Your new receiver probably has about the same power as the
factory amplifier, so you'll get great results if you choose this option.
If you really like the sound of the factory amplifier, we also have two OEM
integration adapters available that will allow you to plug the new receiver
into your existing amp. There is an extra charge for the integration
adapters.
The Scosche model is item number 1421bfdk5 and it requires some adjustment
to tune it for your Ford sound system.
The other adapter we carry is from Sound Gate, item number 55303frd2, and
this adapter is pre-tuned for your Ford factory system so it doesn't require
any adjustment.
In answer to your question about installation accessories for your '92
Explorer, I've got great news! We have everything you'll need to install
your new equipment in stock. Here's the list:
Item Description Price
000car3 Installation guide book Free!
176F14 Mounting kit $12.00
150DINTOOL Radio removal tool $ 3.00
0000190101 Master sheet Free with purchase!
120705004 Bypass harness $11.00
OR
1421BFDK5 Scosche adapter $49.95
OR
55303FRD2 Soundgate adapter $89.95
When you're ready to make your purchase, just place your order using our
Complete Online Order Form at:
Dead Link Removed
~~~i didn't think i even had an external amp all i want is the harness that goes from the back of the deck unit to the factory wires, is this bypass thing the same deal or what?
thanx!!
adapters.
any adjustment.
OR
OR
Dead Link Removed
thanx!!
