i need help | Ford Explorer Forums
i need help
duster373
bonney lake wa
1992 ford exploere
i have a 1992 ford explorer 4x4 Eddie Bauer i have 31s on it now but im going to lift and put 33s on it but i have a ? how does the block lift work with the leaf springs under the axle
As you probably have guessed already, "lift blocks" don't lift the vehicle when the spring is under the axle. In this configuration, "lift blocks" actually lower the vehicle.
so if i put a 5inch lift block would it lift it or lower it since the leaf spring is under the axle
so what wood be a way to lift my rear end
