IAC problem? | Ford Explorer Forums
IAC problem?
Pheonixx77
NY
02 sport trac
:fire: just wondering if i am guessing right... when i start my truck it idles a bit rough but what bothers me most is when i shift into drive it acts like it wants to stall then with a bit more pedal it goes ok...this usually only lasts a short time, pretty much until the truck is warmed up...any other thoughts????
It could also need a tune-up.. When was the last time you changed the plugs & wires on it?
Could be needing a tune-up, but those symptons are usually textbook dirty IAC. Simple enough to remedy.
well i did the plugs, wires, oil, radiator flush, trans fluid, cleaned MAF and steam cleaned the carpets about 9 mos ago.
