Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
I remembered when I replaced my IAC a while back I put on the Napa provided gasket. After reading Aldives above instruction post I realized that the IAC for the Explorer does not need a gasket.
I took it off tonight and found that the glue I used to secure the brass fittings- (I torqed them down way to tight, with bad information and they broke loose) did not hold tight enough. The IAC was not on solid.
I wonder how I can get these brass fittings to bond to the upper manifold again. Would love some suggestions.
Funny thing was that was not the problem. When I took off the IAC I noticed a large piece of silver foiled lodged in the first hole. Don't know where it came from but I took it out with some tweezers and re-installed. Truck idled much better but I still need to find a way to tighten it down to the manifold.
