Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
I was having an idle shudder issue with my explorer. When I brought it to the dealer they told me it was an IAC valve issue and that I should wait until the truck stalled constantly and I had to keep my foot on the brake and the gas to keep it running.
It does the stalling/ shudder thing the most about 5 minutes after starting the truck when it is cold and it has been sitting awhile. After the truck is fully warmed up the shudder only shows up every 3 minutes or so and not to the level of stalling the truck out.
I replaced the three year old Napa IAC with another new Echlin Napa IAC and the truck still had the same shudder problem and weak idle. What are the odds that I have another bad IAC valve from NAPA? Can other components cause a poor idle, assuming that all the obvious components are good i.e. Clean MAF, Good wires and plugs, clean fuel system etc. Do the aftermarket IAC's have high failure rate?
Also one mechanic was certain it was the IAC because he said the idle did not kick up when the A/C was turned on at idle. I guess it is supposed to do this without fail.
I Want to get some advice before I dump another $100 on a Motorcraft IAC and have the same thing happen.
