Starting problem after IAC problem | Ford Explorer Forums
Afboy143
Tampa,FL
1999 Ford Explorer Sport
Well a few days ago my truck wouldnt start at all. It would turn over just fine but not start. I cleaned out my IAC which helped but did not fully fix the problem so I ended up buying a whole new IAC. Now when I go to start my truck it takes a lil bit to start up as before I had the problem it started right when I turned the key, it also idles kind of rough now too. Anyone know what I can do? Thanks guys
Did you disconnect the battery to reset the computer.
yes for 10 minutes
anyone?
Donny says vacum :)
I would check your vacum pressure. My guess is that you have a leak somewhere. Possibly a hose came off. This is only if the problem persists all the time warm or cold.
mikeh
