sirhk100
- December 19, 2000
- las vegas
- '91
Hey everyone... Mine is your normal '91 model. I need to have my ride smogged by sat so kind of up against a wall here and running out of ideas. The engine was rebuilt 600 miles ago. New rings, honed cylinders, new heads, gaskets, seals, ground the valves, etc... Sat I replaced all the plugs and wires. The plugs I pulled out all looked text book perfect even with the miss. Coil pack is working cause I would think if it had a bad bank it would be REALLY missing considering it functions in pairs basically. Loose one, you're loosing 2 cylinders really... The miss is pretty minor. I replaced the fuel pressure regulator last night cause I found gas in the vacuum line. Replaced the intake air temp sensor tonight cause I found it was bad also. I swapped out MAF's last night, no difference. I have a spare throttle body but didn't swap cause I don't see how that would make a difference. Unplugged the throttle body though and it definitely runs different so I'm assuming it's functioning. Same with the IAC, unplug it, engine runs a bit goofy so assuming it's good. Sprayed every remote spot of a vacuum leak and didn't notice any change in engine rpm. I'm pretty confident I don't have any vacuum leaks as I just routed and hooked it all back up myself 5 weeks ago when I slapped the motor back in. BTW, I had the miss before the motor rebuild, thought it was due to a goofy cylinder I had but rebuild and still the same.
Kind of at a loss for ideas right now though. I'm going to hook it up to a smog machine tomorrow and just have it checked and try a couple things to maybe sneak it into the passing numbers and if I can get it there, we'll run the test. That will at least buy me some time but I still need to fix it.
I do have a minor exhaust leak at the passenger side collector I need to pull it loose and just remate it and tighten it back up but I don't see that causing it to run like it has a miss. I also would've thought I'd have seen something on the plugs I swapped out Sat but like I said, they were a perfect tanish brown color. I've triple checked the plug wires, they're all seated properly.
Ideas of other things to check? I don't see how the IAC would cause a miss, I could see a surging idle or odd idle RPM but not a miss. True? Throttle body shouldn't affect a miss?
How's it even really a "miss" if the plugs look great? It sounds like it's running on about 5.5 cylinders. Has power at rpm but idles rough. At the exhaust you can hear/feel it puffing like a miss. No pops, sputters, backfires, etc... Just a very mild rough idle like it's still firing on all 6 but just running a little off. I really was hoping and thinking it was going to be the FPR last night pulling extra gas thru the vacuum line but like I said, new one installed and no change other then it doesn't crank as long before it fires up now. I may pull the new plugs again tomorrow night just to check them again though. BTW, motorcraft platinums with bosh 8mm wires.
Ugh, stupid exploder!!! I can afford a WAY nicer ride then this with a cash purchase but I honestly really like my ride. Sometimes though I really wonder if the headaches are worth it though!
Thanks,
Khris
Thanks,
Khris
