97ExPxLt
- January 19, 2009
- Oak Point, Texas
- 97 XLT
I've got a 97 ford explorer 4.0 ohv. It idles really rough and has no power. I know its missing on cylinder 6. So I checked the ignition system (plugs, wires, coil) everything was good. Checked the compression and I can't remember but I know it was over 100... So the only thing left woudl be a fuel issue I would think so I change the injectors and still the same thing. So finally I check the fuel pressure and at idle with the vacuum line hooked up on the regulator is was at 30psi with the vacuum unhooked it rose to 35 psi, so I replaced the complete fuel pump assembly, fuel filter, and regulator.. And still the same thing. I'm completely stumped on this one... Anyone got any ideas?
