djtof
- October 15, 2012
- France
- 1996 Explorer XLT
Hello,
I'm French and my english are not very good
I bought an Explorer 1996 OHV V6 and I solved some problem.
But I have one which I didn't find the solution
My engine start correctly
But in idle I have a little problem, my engine sometimes have not idle correct.
I think it's 1 cylinder which have a spark problem.
On the road during acceleration, the engine shakes when I feel that the engine is not at the max power.
I checked the OBDII, and I have no error code.
I changed the spark plugs and the beam. But the problem are here.
It is equipped with LPG and the problem is the same, the idle is not correct and acceleration too.
I think a coil problem but I'm not sure.
I also have another problem, with ScanXL and scanmaster, by the OBDII,I have not access to the value of the lambda sensor.
Maybe a problem with the LPG ECU.
Anyone have this problem?
can you help me?
can you help me?
