nostarttireflat
- March 10, 2004
- Phx, AZ
- 91 ExploDer
I failed my emissions badly, My carbon monoxide (CO) test was 221.22 with 20.00 allowwed. Basically, using too much gas. Did the basic tune-up things (plugs, wires, oil) not knowing that these things were the LEAST of my problems right now. I've also changed the O2 sensor before I knew that you should check to make sure if it is bad first or you will .05 & .10 yourself to death. I've done alot of reading and have checked many things from suggestion. I have the rough idle 5-600 jump 9-1000, stutter at times from stop, gutless, eats gas so I changed the IAC valve due to many things the same but N_F_G everything still the same, I've read something about making sure the manifold bolts are tight. Well many were loose only to realize that it was the valve cover bolts that were loose, I've asked a few mechanics (they will only touch a wrench during work hours so asking ?s is the same) if the valve cover gaskets (which I knew had a leak & needed to bo replaced but passing emissions is the major priority right now) that had leaks in them could have any effect on my emission being so bad, they SAID NO. Well 11 of the 16 that I could easily get to (get to late to work for where I live) were extremely loose. More than I'd like to admit loose but like my username will tell you how much I know about cars 'If your car don't start, your tire must be flat'. Does the valve cover have any simularity to the manifold or am I reaching for something as my username suggests? I've checked many of (but not all yet) the sensors, MAF TPS ECT & a few more but seem to be getting no-where, I can't really afford to put in a shop since I'm a sinlge father with custody of my daughter. But soon to have no hair left from this soon to be RESERVATION DECORATION.
