That would be the fx4 level II...sometime after 2k...
That's the one!
I absolutely exploded one of those in my mustang, on the starting line at lone star raceway, in Sealy, TX. Put it in neutral, it wouldn't roll. Had to put a floorjack under the differential to get the car off the track. It looked like the worm gears had forced their way out of the body of the carrier.
This was behind a 5.0 & t5, no blower, no spray, just an explorer gt40p long block with an e303 cam and suitable combo.
Here's why: IIRC, Tractech, then (about 10 yrs ago) makers of tru-trac LS and Detroit locker differentials (both full carrier type, not add-on kits for OEM carriers), had listed in their tech notes that the tru-trac was "not recommended" for use with:
1. Racing slicks
2. Tires 31" or taller
Apparantly "not-recommended" is corporate disclaimer talk meaning you may cut your finger on the razor sharp shards of shattered iron in the bottom of your diff housing. The Fx4 unit I destroyed was, I think, a Gleason torsen that was made especially for ford. They make one without preload which (like the preload-free tru-trac) needs SOME traction to work. They also make one WITH preload that will work with a wheel in the air. I was told that the fx4 unit was sort of a cross between the two, and also that the tru-trac warning about tall or sticky tires also applies to Gleason torsen units. Apparently its a characteristic of worm-gear diffs that they NEED a bit of slippage and, in case of drag slicks or tall tires that really stick, the pent-up forces are too extreme.
So... I would love an awd with tru-trac or torsen diffs front & rear and oem height snow tires, for getting up to ski & snowboard areas at the top of icy mountain passes. Or racing on a frozen lake. Or wet-weather racing on asphalt, or safe city driving in places it snows, etc. I'd like one in my mustang to help get moving on rain-slick streets. Anywhere you have "regular" tires and slippery surface.
For many many years there were only 3 options for basically all Americanist cars & trucks - 1. Open diff, full slip, one-wheel peel; 2. Clutch-type LSD; 3. Detroit locker...
So for the entire time from the invention of the v8 up until relatively friendly, the "go-to" diff has been the Detroit locker (when LSD wouldn't cut it), and since they were a factory option, suitability for street use was never questioned back in the day. As mentioned above, the new ones are supposed to be even smoother. From what I can tell, the Aussie and p--traxx add-on units are basically retrofitting detroit locker type internals (ratchet action) into another manufacturers carrier. usually, things that are "converted" don't work quite as well as things that were designed to be that way on the first place. Look at a Detroit or grizzly carrier with its closed conical shape, and look at an OEM carrier with big open windows, and guess which will break first. Look at the diameter of the add-on type ratchet discs, and compare to the diameter that will fit inside a carrier that is specifically designed to house it... just something to think about.
