taxx
Make em say Ugh
- June 11, 2001
- Indianapolis, IN
- 73 EB
Ok it is getting to the point of doing something about it real soon. Coming from the front drivers side wheel I have a bad vibration(not the tire). It started at highway speeds as a vibration and an occasional grinding(possible a bearing). At that time if I engaged the 4x4 and turned on pavement it sounded like the front would explode (I know dont use 4x4 on pavement...), but anyway, during wheelin yesterday I accelerated the wear and tear and it would clunk and squeek in 4x4 while turning and climbing stuff (CV joint?), then on the way home it was the worst grinding/squeeking noise i had ever heard and alot of vibration. I replaced the outer hub/bearing assembly last november, I wouldn't hink it would be shot already, but maybe. Short of tearing it all apart how can you tell if it is outer, inner, or cv? Or something else? Should I replace both the outer and CV axle just to be on the safe side since it could have damaged the other?
