install of a mini spool | Ford Explorer Forums
firefighter 20
va
92 explorer sport
can anybody tell me what all is needed to instal a mini spool in my 92 explorer sport and how to install it any help would be greatly appreciated
Depending on how mechanically inclined you are, it's not bad. If I recall, you just pull out the c-clips, slide out the shafts, remove the spider & side gears & replace with the mini spool. I ran one in my 8.8 & would say I'm not too much of a mechanic, but certainly up for the do it yourself task.
thanks dannyboy do u know if i am gonna need a c clip eliminaor
No, you will need to put the "c" clips back in.
Your not planning on putting a spool in the front axle are you?
Good.
You do NOT want to spool a steer axle.
The mini spool will have the slots for the c-clips's, some have a piece (block) that has to be removed and then reinstalled after the clips are in.
is a mini spool better than an Aussie locker?
Not if you plan on driving regularly on paved road.
