instrument cluster 96 5.0 etc.
Are you saying your OD does not work
Yes, I am saying that my odometer doesn't work. The odo gear is stripped because I was stupid and tried to reset it while I was on the turnpike at about 70mph. That's the only reason I am interested in an instrument cluster. The gears that operate the odometer/tripmeter strip out when us old folks get touchy feely sometimes. One is the worm gear, the other is I think a 30/40 tooth cog. They are readily available. I'm just trying to find out how much it takes to replace them after one pulls the cluster out. I know that I will have to pull the speedometer and at least remove the cover, but that's all I know for sure. I'm sure that it's easier to replace the whole cluster if one can locate one at a reasonable price. I keep getting beat out at the last second on ebay, but I'm going to keep trying.
