MusicLover
- June 20, 2016
- Location
- Winnipeg, Manitoba, Canada
- 2004 Explorer Sport Trac
- Callsign
- MusicLover
I have a 2004 ST and the instrument cluster will lose power intermittently. The gauges all go the the position when the key is off. And also the radio loses power, and the power windows lose power.
It will come back on a few minutes later, sometimes this is in a TEST mode that appears where the odometer is displayed, but not always. Either way, after driving for a few more minutes, everything comes back on and works fine. Weird thing is, even with a full tank of gas, the "low fuel" tone will chime, even though nothing is displayed on the led display.
Anyone ever had this problem before? Could be the wiring harness between the front driver's door and front pillar grounding out, could be a loose connection in the harness in the dash panel, could be a cold solder joint in the cluster itself.
Just seeking a starting point on where to look first.
Thank you.
Thank you.
