Instrument Panel Plastic? | Ford Explorer Forums
erixon
Edmonton, AB
99 Sport
Does anyone know if there is a way to separate the clear plastic from the black on the instrument panel cover? I assume you could heat it up, and it would pull apart, I just don't know how hot you'd have to get it..
In my 2nd gen that entire piece comes out after taking apart part of the dash, then there's just bolts holding it together
All the ones I've seen are glued together. You can take them apart but usually you have to use a razor knife to seperate them..
