Intake coolant leak - does intake flow coolant? | Ford Explorer Forums
trooper8
Southern California
94 XLT
94 4L 2WD Auto Air EXP
I have a coolant leak right side front where the head/Intake join beside the heater hose area. Does this intake have a coolant passage?
Wondering if this is an intake gasket or possible cracked head... Thanks
Yup, lower intake gaskets....
It's probably either the lower intake gasket or the head gasket.
Usually the heads on these crack on the inside, between the valves or cylinders, not where it would cause a leak. It might cause coolant to get into the combustion chamber.
Check everything else though and be sure it's not a leaky heater hose, bad hose clamp, or one of the block expansion plugs rusting away.
