intake manifold bolt sequence | Ford Explorer Forums
manningzac
livingston, Alabama
1994 explorer
i have a '94 X and i am replacing the head gaskets, intake gaskets, etc. and need to know what the bolt tighting sequence is. and as far as anyone one knows is there anything i should be careful about while replacing all the gaskets.
Intake manifold torque sequence
Put a dab of RTV in the corners of the intake when doing the intake gaskets. And when doing the head gaskets make sure you replace the head bolts.
thanks man ill let you know if i have anymore questions
since i blew a headgasket is it nesacerry to get the heads checked?
Since you have the heads off I would definitely get them magnafluxed and milled. These heads are very prone to cracking. If there is a problem with them I would just replace the heads, you can get them pretty cheap from Clearwater Cylinder Head.
on that website, is the price for one head or the pair
The price they list is per head.
