Benjam
- February 21, 2011
- WI
- 92 XLT Stick,4x4, 422 cam
So ever since I put the engine back in my exploder I've been having an interesting sound when I come off the highway. I've been living with it for probably 5-6 months now but I feel like its time to take care of it.
The engine specs are as follows:
Stock rebuilt 90tm bottom end. new pistons, rings, main, rod, and cam bearings. 98tm heads from alabama cylinder head, opened up exhaust ports.
422 cam
Smith Bros pushrods at 5.550"
Stock style new rocker arms.
Borla Headers, wrapped.
Probably 10k miles on this rebuild except for the cam, probably 5k on that. 410 wasn't enough
Now for the sound.. It mostly makes itself known when I'm coming off an on-ramp, waiting for traffic in front of me. So at idle. It sounds like a terrible heat-shield rubbing against marbles in a can rolling around. It seems the sound comes mostly from the pass. side of the engine bay. If I give it gas it just gets "sharper" in sound until it revs up enough to overcome it, and sounds normal again.
Also worth mentioning, occasionally at idle I have a slight metallic sound, almost like a heat-shield rubbing somewhere. Now this is odd because there aren't any heat shields on this truck that I'm aware of.. I have to believe these two issues are related.
I've had these borla headers on before this specific build of the engine, but same truck and not wrapped with no issues. Part of me wants to believe the header wrap increased the diameter of the pipes and is rubbing against the engine block when it heats up and expands?
It's hard to describe the sound but I did my best .
The sound doesn't change on 87 octane or 93.. I was thinking spark knock for a while but there is no change at all between different octanes.
Any ideas, gentlemen? This thing has been drivin me bananas.
Benjam
422 cam
Benjam
