stuartr
- January 18, 2010
- Richlands, VA
- 2002 Mercury Mountaineer
I noticed that a while back my external air sensor was getting off. Now it is getting way off. It said 100 this morning, BTW I live in teh mtns of VA so it was more like 30-. So on with the problem. I have seen how to fix this thing easy enough. But would it be screwing with my air cond/heat inside the vehicle. This morning seemed like it was throwing heat out of the floor vents, where I had it set. I could feel a bit cooler air coming out of the upper vents that are the ones that hit your side glasses from up on the dash. Also seemed like heat wasn't getting as warm as it used to. BTW I have the dual side digital climate control auto heat system. Not sure if the sensor is the issue, I have read stuff about the blend door or maybe it is a thermosat going out? HELP!
STU
STU
