Interior sqeaking | Ford Explorer Forums
Interior sqeaking
spta97
NY, NY
2000 5.0 AWD
What's the best way to track down sqeaks in the interior? I have what sounds like metal to metal sqeaks when I hit a bump but it's hard to trace them down while driving. Are there common areas where these sqeaks happen? It recently got warmer in NY so I guess that's what is causing them.
personally, i would try to seclude it between the doors and the rest of the car. Most of the squeeks i get are from the inside the doors, most noteably the Window Track inside the door squeels a whole lot. But i have a 92...
Any type of hinge could make noise. Check your rear hatch door and stuff like that. It's funny I saw this post, I have a '00 and I'm having some noise problems...but I think it's my rear spring bushings, not the interior.
-Drew
I think it may be coming from under the seats. I lubed up the door hinges (not the tracks though) and I can hear it when all the windows are up so I don't think it's suspension related.
I actually have a slight sqeak from what I'm guessing is my driver rear leaf spring. That seems to happen when I hit the gas or get out of the car. It's not too loud so I'm not worring too much.
Let me clairfy the window track problem. Lubing them up wont help, its a problem with the brackets holding the track to the inside of the door comming loose, getting debris inside of them making tons of squeeking and squeeling.
i spent years trying to fix them and yet i have just now figured out the trick to fix em. Sound proofing, haha.
if you can get ahold of some sound proofing ($25 for 6'x6' generic stuff from sherwin williams) use a small peice to put infront of the bracket, where the bracket meets the door. once you get the small peice of proofing on, use a small torch to melt the proofing enough to where you can mold it perfectly with the metal (door). make sure you make a little hole for your bolt to go through, and that should fix the rattles comming from that bracket
I noticed with the first gen explorers and the broncos, that the brackets used to hold the (back) speakers would make this crazy buzzing noise. sound proofing (where the bracket meets the metal panel) will fix that also.
if the windows are up, and you get tons of squeeking over bumps and stuff... and if you crack the windows a little bit does the rattling/squeeking go away or become minimal? Then if you put the window all the way down does it squeel more?
if you answered yes to these questions i can bet money you need to do something about those window tracks. Try taking off the interior door panel, from there, there is thin (but not easy to rip off) plastic insulation, if you can get behind that you can see the window/motor ect. To the far left you can see the window track. Try tapping on the track, if thats your sound then BOOM!
