HiImTodd
- June 3, 2023
- Johnsonburg, Pa
- 2015 Ford Explorer XLT v6
My 2015 Explorer XLT 6 cyl. 4wd has been having issues with starting the past couple months. It will start with a jump and then if the weather is hot or if the interior gets hot it won't start and the windows won't even go down and the radio screen starts synching randomly and only clicks when you turn the key. A few hours later without touching anything and it sits in the shade it starts right up. I replaced the ignition switch and the starter relay in the fuse box under hood. Nothing helped. My battery reads 15.2 volts and the connections are tight and no corrosion. Is there a sensor sticking maybe? I have a hard time believing it's the starter because of the other battery issues and the re synching on the dashboard. Anybody smart enough to figure it out from their chair would be appreciated. Thanks, HiImTodd
