BlindViper
- August 23, 2007
- York, PA
- 2011 explorer limited
So my wifes explorer has two issues. Back story we bought this used with just under 100k miles(106k) now. Had no issues for 6 months the the a/c clutch went out. So I replaced just the clutch. Worked great then failed after 2 weeks(bearing failure). So I said the hell with it and just got a new compressor. I installed it and charged the system and all was fine for 2 weeks and the wife said the a/c wasnt as cold. So I pulled the compressor connections and one of the orings had a slightly smaller cross section. So new seals and started to recharge the system....
As I started to charge I noticed the compressor wasn't engaging. So I checked the connection it was secure. I noticed playing with the harness the clutch started to engage. I pulled the compressor to check the coil and wiring. Bench tested the coil and no amount of manipulation would cause it fail. I checked the continuity of the wires back to the fuse for the power and to the relay that controls the ground. So whatever controls the clutch I guess isn't turning it on. Anyway I gave up on fixing it yesterday as I was ready to burn the whole works to the ground. In putting everything back together I arched the alternator charging wire on the low pressure line and blew a hole clean in it.
Wife had a appointment to make so I put it back together. She left made a few stops with no issues. When she went come home it wouldn't start. It would crank with no issues just wouldn't start. One of the guys tapped on the starter and finally got it going. Now obviously it was cranking and tapping on the starter did nothing. Fast forward to this morning it seems to start 10% of the time. It runs fine with no issues. I tried to spray starting fluid and did nothing more then spudder. I swapped all the relays around and to no effect. No CEL or codes.
My thoughts on the a/c clutch is to replace the a/c sensor on the high pressure line.
Anyone have thoughts on the starting issue?
