Just realized that I need to take the cover of the rear differential off in order to replace the oil, right? For my 98 5L V8, it calls out 80W90 (I will probably use 75W90 synthetic) for the front and 75W140 synthetic gear oil. Do I need any additive for both? The owners manual is hard to understand as below.
Note 3, Vehicles equipped with 4.0L SOHC or 4.0L EFI engines and 3.73 or 4.10 rear axle ratios or 5.0L engines require synthetic rear axle lubricant. Rear axles containing synthetic lubricant are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected, service required or the axle assembly has been submerged in water. The axle lubricant should be changed any time the axle has been submerged
in water. For Traction-Lok rear axles, add 118 ml (4 oz.) of additive friction modifier C8AZ-19B546-A, Ford specification EST-M2C118–A, whenever the lubricant is changed.
