frickea86
Rust? You mean character!
- June 18, 2003
- Pittsburgh, PA
- '97 XLT SOHC
hey guys, i have been having this problem lately when the weather has been cold out, 20F or below. The truck has no trouble starting but once it started it dies down to rpms way under 500 and is barely running until it kicks back up to its normal starting rpms at 1500 when its cold. Normally it jumps right up to 1500 or so and then starts dropping down as the engine warms up. This just seemed to start this year.
My thoughts on the matter are:
1. Could be a fuel pump, because starting this fall after the truck was running for a while, if i turned it off to go run into a store and come back out and start it, the engine would just crank and no run. Turn the key all the way back to off and try it again, starts right up. Only did this to me two or three times.
2. Might be the IAC Valve is not moving as fast as the computer wants it to and is chocking off the engine.
3. I have an alternator going but the battery is still good and starting amps are 13.8 volts when the battery is cold. But never the less i still tested the battery and it passes, battery doesn't loose much voltage. So my only thought is once the truck starts it doesn't have enough juice to keep going until the alternators starts charging the battery back up. I highly doubt this is the cause.
Sorry for the length of the post, any suggestions?
Engine is a SOHC, fuel filter has been just replaced about 5 months ago.
