floydr007
- February 17, 2006
- Binghamton, NY
- '99 Sport
Hey everyone, i just searched this because i figured it was common, but i didnt see anything exactly like my problem. My 99 SOHC sport sits outside in a parking lot (im at school) for up to a week in between when I use it (its been anywhere from 20-40 degrees). I used to struggle getting it to start sometimes (Id have to hold the gas pedal like 1/2 throttle and hold the starter for a few seconds). Well i took it to a shop, and my throttle body was pretty dirty, so i had that cleaned because I thought it might be restricting airflow when the throttle is closed. All was well for a few weeks. Just last night, I went to start the car, and it started immediately, except it would not idle after i started it. I had to press the gas pedal to keep it at about 1000 RPM. i let off to see if it would just fix itself and it died. Also, when the rpm's would drop down real low, all my interior, and headlights would dim and almost turn off. I started it again and revved it to about 3500 or 4000 rpm, and it just settled right back at a perfect idle, and there were no problems for the rest of the night. Do you think my IAC is bad, or possibly an electrical system issue? By the way, I have a MAC intake, do you think that one breather might be leaking? Thanks for the help.
jonathan
jonathan
